1g cas in a 2g (97)
tode5tool
122
Jan 21, 2010
fort hood, Texas
ok, im a little confused on this 1g cas in a 2g. um... where do i start. 1st ive talked about this before but not this far into the job. just what i should do about my car running on 2 cylinders. now im actually installing the cas and harness. rre and vfaq shows a harness with 3 plugs. one of those plugs is wrong the square gray one. that one dont fit anything on my car. its supposed to go to the 2g cas plug but its the wrong one. the one for the 97 on magnus just has 2 plugs, one for the 1g cas and 1 for the cps.
SO. i have the 3 plug harness. how do i make it work. or more specifically how do i make it a 2 plug harness. because my car is still running on 2 cylinders.
and do i need to change my injector wires around or what. because i fired it up.. and fuel went everywhere. maybe that's because my injector o rings are shot.. idk.
i also have a wtb ad up.. i need a new ptu plug.. i have a strong feeling its my ptu still. my plug is shot.
ug... i don't need the rre instructions.. i used those to get the 1g cas on.. that was no problem. this is a harness issue. i need to know how to make a 2 plug harness.. magnus's to be exact. i have a 97.. the 97 don't use the gray square plug. or at least i cant find it.. and its not the 2g cas plug.. they are totally different sizes. the magnus harness has a 1g cas and a 2g cps plug with a single wire by its self.. that wire gos some where, that's what i need to know.. and exactly how the plugs are wired together. this is what it looks like.
