1g Bov help
Not directly. You need a U pipe to connect to a T25/T28. There are a few companies that make a FMIC for stock setup, although you may actually lose a little power using a FMIC with a T25. Save the FMIC for when you upgrade turbo, then figure out what kit to get for that turbo. A hard upper pipe can be a good investment as you can use it down the line with a universal FM kit. That's what I did, but only because most FM kits need modification to fit automatics.
So should I just get hard piping that connects to the stock side mount ?
If you want, go ahead. In all honesty, I never really noticed a difference. Unless you never plan on upgrading your turbo, I would just get the adaptor. The top three early mods I noticed a difference with were getting rid of the stock bov, intake pipe (at least get a cone filter and hack the stock pipe), and catless 3" exhaust.
I only had the hard pipes with the stock sidemount because I got them with a greddy bov for $80. If the stock pipes aren't leaking I would spend my $ elsewhere. Like a boost gauge and MBC.
