1G 1G AWD flywheel cover plates top and bottom
99 gst spyder
522
Jul 12, 2007
st. paul, Minnesota
Will I have a problem without having the flywheel covering plate for both top and bottom. I know it can contaminate anything inside the bell housing and yes, I can see the flywheel just by looking at it from the ouside. When I took the motor apart for rebuild, there wasn't any cover.
Another thing, I went to install the starter and I wasn't sure if it needs the top plate for the starter to be in the correct place other then screwing in the bolt pushing the starter to close or something.
Thanks
it actually goes behind the flywheel so youll definitely have to pull the tranny to do it and remove the flywheel too. there are two bolts behind it I believe
dsm graveyard stocks both new for the 6 bolts for like thirty bucks for both
