Sold 1g/2g Performance and OEM parts
GregoryRyan
Supporting Member
168
114
Jul 22, 2013
Millstadt, Illinois
IF THIS POST IS UP THIS IS STILL FOR SALE
Prices do NOT include shipping and PP fees. Will not ship larger pieces. Open to trades.
Genuine MHI EVO III Big 16 turbo and ported O2 housing - 380$
4g63 freshly machined block: 450$
Decked
Bored .02
Hot tanked
Oil galleys ported and polished
Fresh coat of black paint
Cylinders lubricated
OEM Crankshaft
OEM Oil pan and baffles
4g63 cylinder head: 125$
110k miles on head
Valve cover
OEM cams
OEM springs
OEM lifters
OEM complete front suspension (NEW): 300$
Upper control arms
Both lower control arms
Outer and inner tie rods
End links
OEM wheel bearings (NEW): SOLD
All four corners
Koni Orange (NEW) 300$
B&M Oil cooler, A/N fittings and lines (NEW) 200$
Full timing belt kit (NEW): 220$
All Tensioners
Water pump
Belt
OEM Water pump bolts (NEW) 8$
FEL-PRO HEAD GASKET SET (NEW) 100$
OEM Balance Shaft elimination kit (NEW) SOLD
Braided oil feed line (NEW) 55$
Exhaust manifold stud kit (NEW) 30$
ARP Head studs (NEW) 125$
ARP Turbo bolts (NEW) 25$
PowerStop GSX full brake kit (NEW): 375$
All four corners
Rotors
Ceramic Pads
New Calipers
Russell Performance braided brake lines (NEW): 80$
All four corners
StopTech Street pads (NEW): 60$
All four corners
BC 272 Intake and Exhaust Cams (NEW) 430$
BC1100 Valve springs (NEW) SOLD
GSC 2001-8 Chrome Polished Exhaust Valve - 30.5mm (NEW) 115$
GSC 2002-8 Chrome Polished Intake Valve - 34mm (NEW) 115$
GSC Viton 6.6mm Valve Stem Seal Set (NEW) 12$
Walbro 255lph High Pressure Fuel Pump (NEW) 75$
OEM Non cruise control cable (NEW) SOLD
OEM GSX gas filler neck (NEW) 50$
96 GST Auto transmission with 150k miles: 60$
All gears work perfect
Speed sensor
Front mount attached
Labeled bags of teardown bolts, brackets and misc. assortment of things related to a 4g63 teardown. OEM exhaust manifold, intake manifold and stock T25 turbo. Also will include a box of OEM parts and pieces that came off my running 96 GST (Fogs lights, alternator, stock intercooler, gauge cluster, hatch cover, cup holders, valve cover Mitsubishi cover ( etc) pictured below.
Take all this crap out of my garage for 200$
rsx, rsx type-s, type r, gsr, integra, dc2, civic, hatchback, ek, eclipse, talon, 1g, 2g, wrx, wrx wagon, rx7, k swap, k24a2, k series, k20, ej205, ej255, 3000gt, vr4, awd, rwd, 4g63, supra, evo
  • Wanted 4G63 Wanted
    Looking for a kiggly HLA
    • steelcurtaindsm
  • For sale 2g 1998 Eclipse GST Rust Free
    Rust free, not perfect, prob needs motor soon. 125 compression all 4
    • Zanaqqq
  • For sale 1g Int door plastics MB517837 and MB517834
    • ist dwa
  • Wanted 2g WTB CLEAN HVAC PARTS
    Good condition , clean please no rodent infestation
    • ames905
  • Wanted FIC Easytune
    Looking for a FIC Easytune box.
    • Stapl3
