GSXlaunch
- 392
- 0
- Sep 3, 2003
The past couple of times I have driving the car the egt gauge has been stuck on the last green light meaning it is full rich. This only occurs once the car has been driven for a while, otherwise it works fine. I am trying to figure out what is causing this. Perhaps it is a simple connection problem. I did notice that my logger shows O2 FT at 100% as soon I start getting on it. If I am just cruising, FT% fluctuates normally but as soon as I start to give it more gas it goes right to 100% and stays stuck there. My fuel trims are as follows:
low = 81.2%
med = 98.4%
high = 85.1%
I am running boost at about 10-12 psi right now but want to up that to 25+ pretty soon. I've got the stg 3 chip with injector comp for 780cc's. I've got my GM Maft trans set to read 450cc injectors. My AFC is set to the following:
800rpm = -8
2400rpm = -10
4000rpm = -12
5600rpm = -12
7400rpm = -4
I am not seeing any knock at all and the car actually is driving pretty good even tho it is running a little rich.
low = 81.2%
med = 98.4%
high = 85.1%
800rpm = -8
2400rpm = -10
4000rpm = -12
5600rpm = -12
7400rpm = -4
