Sold 1990 Eclipse GSX part out California car ZERO RUST
TurboDSM90
Freelancer
1,190
48
Aug 20, 2002
Fremont, California, California
Longblock is gone.
Parting out 1990 Eclipse GSX
NEW OEM Forward facing oil filter housing, never used 6 bolt.
$150
1G 5 speed Prothane inserts with solid front crossmember and shortened drivers side north south bar bracket to keep your crossmember from spreading under hard launches.
$SOLD
6 bolt oil filter housing without the sandwich cooler.
$75 shipped
Transmission 22 spline 1990 Gearset needs a freshen up as 2nd and 3rd grind.
$100 picked up
22 Spline Tcase all aluminum from 90 GSX. Good shape, redline fluid came out clean.
$100 picked up
ACT 2600 pressure plate with stock 1G 6 bolt AWD flywheel and 4 puck sprung hub disc. Used, launched and raced on but has a lot of life left for someone on a budget looking for decent clutch setup.
$SOLD
1GA Mitsubishi front lens and corners set (5pcs) no broken tabs, about a quarter sized spider web crack on one of the lenses. Otherwise in good shape.
Have a red Eagle Talon 1GA center grill as an option $150 for all
1GA bumpers trimmed for front mount intercooler clearance. $75/each. Red and black rough paint all holes for mounting are good.
1990 Shifter cables in good shape $SOLD
Rolling chassis is now sold, small amount of parts left. (1990 water pipe, tstat housing, stock valves, springs, retainers, valve cover, misc stuff).
All prices do not include shipping or PayPal fees. Low ballers welcome, bring a truck and it will be worth your while, lots of parts left.
