18x8.75 +35 Fitment Check!
StrokedSpyder96
31
Dec 17, 2012
Plymouth, Massachusetts
Before someone posts, yes I have searched all corners of the internet for a straight answer, and yes I know there is a similar thread already but it doesn't answer the question it just turns into another completely off topic thread.
With that said, my car is on roughly a 1.5" drop and I am looking to pick up a set of 18x8.75 +35 wheels and pair them with 245/35/18 tires. I am already prepared to do some fender rolling on the rear, but other than that should I be prepared for any other issues?
Appreciate the help in advance, and anyone running a similar setup please share!
The tires are a little too thick and will probably rub on front mostly. I have 18x9 +35 with 255s and don't clear but will be switching to 225s so i can slam the car and not have to run -camber.
Im on 18x8.5 with 225's and +35 offset, I cant get the tip of my pinky between the tire and suspension in the rear. .. id assume your problems would be there in addition to the fenders
What are you running for a sidewall? 35 or 40? Any drop?
  • Wanted 6 bolt NT water pipe
    • chrisman287
