Spyder 18x10 wheels, what tire size?
braden02
Aug 23, 2022
Black Hawk, Colorado
I bought some wheels today, and now im looking for tires. question is, on these 18x10 wheels, what would be a good tire size?
You’re gonna have to stretch like 225/40 or 215/40 on there…
Yep
Basically the wheels are going to stick out past the fenders, if you run any sort of decent tire there will be tons of rubbing and the car will look like it needs to have wide body fenders or extended arches
So to prevent that look you will need to run a super stretched tire.
Im not sure your going to find that answer on this forum, basically you will need to search on google, "whats the smallest tire I can stretch on a 10inch rim"
Heres a profile that looks like he tucked similar wheels
For reference these are my 17x9 +35 with 245/40 DWS06. They’d tuck a hair more without the tiny 3mm and 5mm spacers but I like the look. I will need to roll and pull my fenders a bit due to my ride height.
If you’re not super low you might get away with just a roll because of the stretch. I imagine those wheels are not only wide but low offset as well so they’re going to stick out a bit more than my example.
It’s usually better to do your research before buying. Hopefully you can make them work as they do look nice. My wheels are concave also and I love the look.
Also, not sure if you noticed but on those websites it will show what tire size they run as well as what fender work they’ve done and if they rub or not.
