18g td05 rebuild questions...
empie1
1,063
5
Dec 30, 2004
albany, New York
i traded a kid some cams for his 18g...a couple of the turbine fins are slighty bent (nothing from shaft play) so i was interested in purchasing a whole new wheel as well as a rebuild kit...can i buy a 20g wheel and put that in with out modifacation? or do i have to stick to the 18g? sorry to ask such a novice question....
thanks for your help
If you are referring to the turbine wheel then you will need to know what size the turbine housing is and what wheel you have, before you decide on an upgraded wheel. Some 18g's come with TDO5H turbine wheels and some come with TDO6 turbine wheels, they can also use 6cm, 7cm or 8cm housings. Do you know if it is a Mitsubishi 18g or a Greddy 18g?
same question, i have some burnt up fins and i was wondering if i can change my mitsu 18g to a 20g
Are you talking about the compressor wheel or turbine wheel? There are a few different turbine wheels availabe as I stated above. Either way it will most likely require modification. If you are serious about it call Forced Performance.
