16psi on a T25 turbo...
Originally posted by 98TsiAWD
Yes you should do it, even on your stock pump. If you rewire your stock pump you can run 15psi with your setup. Get a 190 pump and rewire it also and you could probly run 16-17pis but that is pretty much hotair out of the T25.
The rewire is very easy, just take your time and follow the directions. Make sure your doing the right thing before doing it. Study it first.
i can do it now on the stock one and just use the same thing when i get a 190 fuel pump?
