16g to 18g
Originally posted by Spidey
18g compressor housing is different, at least with the Greddy kit
The Greddy 18G is different from a "regular" Mitsu 18G. As you can see from the picture in the link, it comes with a 90-degree elbow which exits from the bottom, so it's a complete bolt-on for a 2G. The turbine housing is also larger from what I remember-- something like a 8.5cm housing.
The Mitsu 18G normally comes in a TD05H housing just like a 16G, but you can also get one in a TD06 housing, I believe.
Forced Performance does 16g-18g conversions. As far as I know, when they do the conversion, they do machine the compressor housing. I'd call them to verify.
Shizz
doodie: LOL, if you are going to consider a 60trim, consider an FP Red.
Doug: Correct sir, my 18G is in a TD06 housing. Supposedly 10% more flow with the larger housing.
