14b with a FMIC? so confused
byebye_sti
164
Dec 25, 2007
Barrington, New Hampshire
So I noticed that the outlet on the turbo that points up, but i do have a J pipe coming off of that down towards the sidemount IC. What I don't understand is how I am suppose to get my piping to the turbo (that points up). I can get the intake side to line up perfectly, its the turbo side that I can't do. Any one have any suggestions? Heres a picture of my piping.
Yep. Had the same dilemma with mine. Couldn't route the 2.75" piping I used past the front motor mount. I used extremepsi's J-pipe to get on the other side of it. It was the same price as ETS's, and not nearly as nice. I, however, mistakenly ordered the 1G version and had to "clearance" the driver's side radiator fan shroud a little. The 2G version which I should've bought had the correct tighter radius I needed.
It doesn't make any sense for him to use the Extreme PSI J pipe considering that he already has the ETS pipes and their J pipe would bolt up perfectly and is made for that specific kit. OP, just get the ETS pipe and get it over with.
I was just sharing my experience. I didn't intend for it to sound like I was trying to convince him to use something different. I was simply stating my personal solution and comparing the identical price I paid for a shorter and raw unfinished piece. I fabbed up my own piping from some aluminum bends I got anyways (because it was cheaper and larger diameter). Obviously, if he already has ETS stuff that would tie in perfectly with their pipe, as I'm sure it does (ETS is top notch!) then it should be a kiddie-hoop slam dunk on getting the ETS pipe.
