14B Greddy BOV TurboXS MBC Install Ques??
JuiceGsTurbo024
167
Mar 3, 2003
209, California
Alrite I did some research and i got all the info i needed But i still have one question? I got a TurboXS Standard BC and i have a Greddy Type S my BOV has two Nipples top and Lower Nipple. The Top Nipple has a vacum line coming of the intake manifold, and there is nothign on the bottom Nipple so my Question is? Do I "TEE" off the top nipple vacuum line or can i Connect the MBC line to the Bottom Nipple on My Type S? and i do i cap of the vacuum line that is on the J-Pipe that is connected to my 14B Turbo? I found this pic its not for the TurboXs but its close? also how much Psi Shold i run with my set up i was thinking 12-13Psi also if you have a good link to installing A/F and BoosT Gagues that be great well thanks for your help and get back to me asap!
Juice
Use the line from the manifold to the BOV as your boost source (tee into it), or better, run a separate line to the boost controller as the source. You can cap the line on the j-pipe, or use it as a boost source, but that's not ideal because it's pre-throttle body and close to the turbo. That said, it does work for the most part.
Good luck,
Ryan
Sweeeet! I went out and I did what you said, i hope this works i am going to be installing my guages today hopefully. when you said i should run a seperate line for the bost controller, how would i go about that? do i run a vac line to the bottom of the BOV? and the other line of the intake mani to the top nipple of the BOV? For right now i am going to be running the MBC with a Tee , like you said? well thanks for your help means alot! Got to Love DsmTuners!!! hahaha
Thanks again!
Juice
Use the factory line for the BOV to the top nipple on the Greddy, leave the bottom (smaller) nipple open, don't cap it either. Teeing the line to the BOV should be just fine. If you want to run a separate line, usually you have to add a nipple to the intake manifold.
Ryan
