14b custom j pipe?
S_Ranger
Banned Member
761
6
Aug 30, 2004
ca, Central America
Can I use a piece of radiator hose to slip over it? Or should I just be patient and find a used 1g j pipe online?
I dont' want to spend 50-100 bucks for this...:p
you can i did it but is such a pain in the ass you might as well and just spend the money cause it will make life easier in the long run. just get the install kit just the 2 pipes from rre or from slowboy. its going to run you about 95 to 100 bucks but is worth it
If it's for a 1g and sidemount, just get the j-pipe from dejon for 50. Unless you need the licp that goes from the j to the sidemount. Then rad. hose will probably work.
Again, please fill in your car profile.
ya, it's for a 1g smic... no thanks to the 50 dollar piece.. I'll see if I can rig it up till someone sells a j pipe for a reasonable price
