2G 12 volt constant to radio no volts
Dirtbike29
134
16
Mar 10, 2024
Surrey, BC, Canada
Red is reading only 1 - 0.8 volts I checked the fuses should I just run a new constant power or is there a common fix?
Try checking these fuses before anything else. Then go from there. You should solve the reason why you don’t have what you need instead of just bypassing it. May fix other things wrong with the car too LOL. Fuses 11 and 12
Oh my bad LOL. I didn’t watch the video. Are you comfortable with a meter? You need to actually check both sides of the fuses and also while at at check everything else.
I finished that I have power to everything but ground I don’t know what my low input goes to on the back of the radio aux L and aux R?
