- Thread starter
- #26
blcknspo0ln
DSM Wiseman
- 7,772
- 101
- Jul 31, 2003
Central,
New Jersey
If anyone ends up searching this, my IDC's went from 100% to 69%, ceteris paribus.; I jumped from Denso 660's to FIc 950s.
kahl23 said:The biggest restriction in the system is actually in the return line. The higher flowing system is trying to shove too much fuel back through the return line, so the pressure you set at the regulator is actually lower than it is at the injectors. Until you fix this, something like raising the fuel pressure at the regulator won't do much. The good news is you can just run some some ss line or large diameter hard brake line to fix the problem.
For the front end of the system: http://www.dsmtuners.com/forums/showthread.php?t=209428
DSMunknown said:I was thinking about that, but on the other hand, who cares if a lot of fuel is just sitting in the fuel rail? Generally at WOT, most of the fuel is getting used up that goes into the fuel rail. And it's not like the fuel pump is pumping at the same PSI the entire time its being driven around town. I undertand that the fuel needs to return back to the fuel tank, but I wonder how "necessary" it is to upgrade the fuel return line for most "normal" applications.
