Mham2k
- 306
- 57
- Feb 8, 2008
Dallas,
Texas
I just installed a DIY meth injection kit on my car and new head studs.
Running 50% Water and 50% Denatured Alcohol (50/50 Meth/Ethanol)
I have a solenoid that triggers on and off with the pump so the car won't siphon the mix.
Problem
- At idle while the kit is turned off if i rev the car to 3000+ it fouls all my plugs and i get a misfire in Cylinder 4. When i drive it and attempt to go above 3000 RPM's the same thing happens.
I assume i have some of the 50/50 mix still in my intake or intercooler that its getting sucked in and making the car go rich.
Or maybe....
Could it be something else with the head stud install.
I installed them one at a time and torqued each to 30, then went around in the pattern to 45, then to 65, then to 80.
Thinking its probably extra 50/50 mix, I just ordered new plugs and wires in hopes that I can burn it all up driving around if that is the case.
Any thoughts?
Problem
Or maybe....
Any thoughts?
