1997 Mitsubishi Eclipse GSX
My 97 GSX that needs a little love
Been a while, but in the last 1.5 years I have gotten around to replacing the steering rack, pump, various hydraulic lines. Had to get a hard line remade due to thread issues on one of the lines.
Also did the full timing belt job with water pump and all pulleys replaced. Did new oem radiator and various cooling hoses. New oem clamps and water outlet tube. Replaced alternator as well due to testing bad at oreilys. Replaced the harmonic balancer with a new oem one.
Installed my new spring/strut assemblies on the rear.
Few things still left. Need to do full alignment. Toe is in on the rear a lot. The front is off for sure and my steering wheel is clocked about 30-40 degrees to the right from center while driving.
Belt squeal still. Guess the tension isnt right on the main belt?
The rear sits really high with new suspension but they're kyb agx with vogtland lowering springs. Not sure why.
Have upper controls arms sitting around waiting to be replaced. Realizing all my rear arms could be replaced too. Did my fronts apart from uppers.
On a side note, I have never replaced a steering rack or done a timing job on any car until this one LOL. I just followed the factory service manuals and online tips as best as possible.
Dont forget to tension that timing belt if you haven't. Its loose in one of those pics.
Yes sir. Redid that part a number of times to get right actually. That was a tricky guessing game with the tools I had to torque the tenioner pulley. But eventually the pin would slide in and out of the tensioner with the slightest amount of friction.
