Street Build Luna
1995 Eagle Talon Tsi FWD, 2gb Eclipse facelift. Road to 300hp
04/21/26 Engine prep. Engine from 1997 GSX, rebuilt 4000 miles ago. Trans 5 speed manual with 82,000 miles on it. OEM clutch with a lightweight Competition Clutch flywheel.
05/24/26 Engine and trans in, mixture of a 98 manual engine harness and a 99 auto chassis harness. Clear cam timing cover did not survive because I was dumb and ran it without the middle timing cover piece. Trying out some Intercooler piping routes, eventually found a stock one to use for the moment. Stock T25 turbo.
06/14/26 Shes alive! Engine sounds healthy (no surprise came out a running GSX) Chasing down boost leaks, stock BOV was leaking majorly of course. Swapped out with a knockoff Greddy type s. Transmission feel and sounds very good and healthy. Now its time to clean up the wiring, find all the leaks, and start breaking her in.
07/23/26 Got the new intercooler piping on, I’m pretty sure the used knockoff Greddy BOV is leaking. There’s a loud continuous whistle anytime I’m in boost. Also boost gauge telling me I’m not building boost. On a worse note my water pump decided to fail right after the test drive.
Better right after a test drive than miles from home.
My fuel pump went out on me like 5 miles from home a few weeks ago, right after filling and on my way home
Exactly, I’m purposely doing all these stress test at the shop to see what’s all bad before I take it home. When we rebuilt my RS I took it home almost immediatly and never caught up with the problems since I dailyed it at the time. Live and learn
