OwenRonn
- 6
- Mar 25, 2026
gulf shores,
Alabama
My AFRatioEst is way off from my wideband and it shows around 18afr at idle while the wibeband shows around 14. the AFRatioEst also has seemingly random large spikes at cruise. I don't think it is related to the MAP sensor because I just installed a new AEM 3.5 bar sensor.
Is it something related to my VE table? I have more logs if needed to narrow down the problem.
But if you change deadtime, it will change everything a little bit, so you'd have to run another log like this to get new suggested VE numbers. I suppose changing deadtime is the most correct way of doing it.
