dwdsm
20+ Year Contributor
- 588
- 45
- Apr 28, 2005
Scenery Hill,
Pennsylvania
Hey all, So after a 7 year restoration we back together and driving. I have a fresh out of the wrap TMZ stage 3 trans filled with Amsoil MTL (tells you how long ago I had that rebuilt...), resurfaced ACT Streetlite, and new ACT 2100 clutch. New TOB, New release fork, so essentially it's all new. Transfer case was rebuilt filled with OEM Mitsu fluid. Boosted fab mounts, Aluminum K member bushings, aluminum driveshaft with JXB carrier.
So anyhow this is essentially a retired race car that will spend the rest of it's days on back roads and at car meets. I expect vibration, in fact it's part of the fun but on decel right around 3,300 rpm and when slipping the clutch I get a metal chatter that is new to the rebuild and a bit concerning. It seems to be getting slightly better as I break in the clutch but not sure if I should let it ride or pull the trans and double check some things.
Kind of hard to hear but second 4-5 of the video you can hear it over the dash rattle... https://photos.app.goo.gl/dvV7VBt7E9V3TC5A9 Maybe I'll throw my gopro under the hood and go for a drive to see if I can capture it better.
