1997 Eclipse Spyder
1997 Spyder GS-T
my build,
Part
Walbro 255LPH & Install Kit #GSS342​
Fuel Pump Rewire Kit #STM-FPRW​
Fuel Pressure Regulator #51502-1​
AEM X-Series Wideband UEGO Sensor​
Russell Fuel Pressure Gauge​
Electronic Booster Control Solenoid​
NGK Plugs #BPR6ES​
ECMLink v3 w/ Eprom ECU​
USB Datalogging Cable​
CX Racing 3” Down Pipe 2G GS‑T FWD​
CX Intercooler #Kit-2G-T25-IC0005-B0v009​
Forced Performance 6851s (68HTA Turbo)​
Megan 3” Exhaust​
Auto Meter Dual A-Pillar Pod​
Fuse Kit​
Glow Shift Boost/Vac Kit 30PSI​
Injector Dynamics 1050x​
ECULink Speed Density Cable #27533​
Speed Density Bundle Kit #27806​
FP Cast Race Manifold #6001010​
STM ACT 2100 Sprung Street Clutch w/ R.M. Seal + Hardware​
Extreme PSI 16G Install Kit V2​
STM Aluminum 3” Speed Density Intake (2.25”)​
J-Pipe Configuration (Front Mount Intercooler)​
Findanza Short Shifter & Bushing​
Misc Turbo Hardware​
Slim Radiator Fan
Mishimoto Catch Can 2-Port​
The big buying is complete. The enjoyment is about to begin.​
1997 Eclipse Spyder GS-T​
STAGE 1: FUEL & MONITORING​
The Foundation
Walbro 255LPH Pump
(Rewired)
Fuel Pressure Regulator (with Russell Gauge)
AEM X-Series Wideband O2 Sensor
Electronic Boost Control Solenoid
NGK BPR6ES Spark Plugs
STAGE 2: GAUGES & EXHAUST​
Monitoring & Exhaust
Dual A-Pillar Pod
(Fastened/Corrected)
GlowShift Boost Gauge
Megan 3” Exhaust
(MR-CBS-ME95T)
3” Downpipe (CX Racing)
Custom Mishimoto Brake Reservoir (Converted Baffled Can)
Custom Fabricated Brake Reservoir Bracket
STAGE 3: TURBO & PERFORMANCE​
Turbo & Power Upgrades
Forced Performance 68HTA Turbo
(6851s)
FP Cast Race Manifold (with STM hardware)
CX Racing Intercooler Kit
STM Air Intake
(Brushed Aluminum)
TiAL 50mm Blow Off Valve (Newest Addition)
ECMLink V3 Package
(Speed Density Bundle)
ID 950cc Injectors
Custom Fabricated Coil Bracket
(with TRQ Coils)
STAGE 4: CHASSIS & COOLING​
Handling & Reliability
Megan Racing Aluminum Radiator
(MR-RT-ME95T)
Tein S-Tech Lowering Springs
KYB AGX Adjustable Shocks
(New Mounts/Boots)
Brake Performance Cross-Drilled/Slotted Kit
Russell Stainless Brake Lines
Nitto NT05 Tires
(235/40/17)
XS Power AGM D925 Battery (Trunk Mounted)
Prothane/OEM Bushing Overhaul (Motor Mounts/Front/Rear/Sway Bar)
ZERO HOUR RELIABILITY​
The "Bulletproof" Maintenance
STM Timing Belt Kit
(Blue Gates Belt/Water Pump)
ARP Head Studs (Torqued)
Cometic .040 MLS Head Gasket
OEM Main Crankshaft Seal
OEM Thermostat Kit
  • For sale 2g 2g auto shift inhibitor with plug
    2g auto shift inhibitor with weather pack plug. Price is shipped USPS. Message 702-741-6987
  • For sale 1g Used 1991 Turbo Engine Control Harness, Auto, with ABS
    Used engine control harness for a 1G turbo, automatic with ABS vehicle, replaced any broken...
    • 19Eclipse90
  • For sale '90 Laser turbo
    115,000 miles. Bought new, lovingly cared for. Very low miles in recent years, mostly in storage...
    • GregPLT
  • For sale 2g factory torque converter
    2g Auto GSX factory torque converter
    • pottersgst
  • For sale JFH REAR
    JFH Auto LSD REAR
    • pottersgst
