Stizzydrew
- 184
- 65
- Nov 11, 2021
Los Angles,
California
This is the Build Thread for 1998 Eclipse GS-T. Reply below.
That light on the right side of the dash is a low coolant level light, not a battery light. The battery light looks like a box with a + and - in it. I Can't find a picture for ya right nowShortly after that happened my dash/headlights completely turned off and would not turn on even if I turned on the switch. That little icon on the right popped up and I believe it’s bad charging/bad battery? I ended up getting a new battery so tomorrow I will install new battery and hopefully it goes back to normal…
That's how the DSM life goes man. I've felt this way before too. I believe they sell our fusible links at auto parts stores. I got my Radiator fan fusible link from Advance Auto, I think it was a pink one. I would take your old fusible link to the store with you so you can compare which fusible links work.Great so after getting a new battery, the battery isn’t problem. The alternator is the problem. I was informed by another DSM user, not only that my cooling hose blew off the radiator through the coolant everywhere luckily I had a jug of coolant, so I filled it up with coolant, drove it back home and haven’t driven it since, this was yesterday by the way. Now. today I installed a new battery to hopefully see and find that the alternator wasn’t the problem as I was hoping.. The alternator is a problem not only that my dash , my interior lights, headlightsand my bumper side markers. Don’t turn on no more. After looking under the hood fuses, my 40A headlight fuse blew. I don’t even know if they make these fuses anymore.To top it all off with the icing my coolant sensor is not reading no more.
WTF? I heard owning a DSM is awful when things start to break but I did not think it is to this extent of a domino effect. Maybe I’m just having bad luck right now or maybe this is just a normal thing for a DSM. But damn I miss driving the car already.
Thanks bro I’ll just get the alternator replaced anyways. Volts are 11.5-12.2 at idle. As for the coolant sensor I will have that checked out and replaced when timing + water pump is done. I found the headlamp 40amp fuse so I will start there and if it works then atleast (I’m hoping) the splash of coolant didn’t cook or fry more of my fuses.That's how the DSM life goes man. I've felt this way before too. I believe they sell our fusible links at auto parts stores. I got my Radiator fan fusible link from Advance Auto, I think it was a pink one. I would take your old fusible link to the store with you so you can compare which fusible links work.
If you want, and if you have the tools, you could test your alternator charging with a multimeter. The coolant could've made its way into the case of the alternator and shorted something. If it was blowing out the fuses, it may be overcharging. I may have this wrong (so be sure to research this before doing what I suggest) but you put the positive lead for the multimeter onto the lug on the alternator (it's behind the orange rubber cover) and have the negative lead going to the casing of the alternator and whatever the value is, is what your alternator is outputting to the fuse box through the Alt fuse, and eventually to the battery. Make sure you have the multimeter on the correct setting.
Good luck and keep your head up!
While I haven't had this exact issue I feel your pain about alternator's.Unfortunately I found out the alternator is bad.
I conducted a small test where i disconnected the B+ Terminal on the alternator and had the battery plugged in, after I replugged the 40AMP fusible headlamp link and it did not pop.
Keeping the fusible link installed and reconnecting the b+ terminal wire on the alternator (always remember to disconnect - battery before removing and plugging in wires) instantly the link blew. I believe that is an indication that the alternator is bad and causing a short? I’m not sure why or what caused it but I will be replacing the alternator and we will see if that was the cause. I hope that’s the case because it’s be simple enough to get it fixed. I hate electrical.
If anyone had this similar problem please do tell and input.
View attachment 774451View attachment 774452
Yo!!! Thanks for the support brotherI just realized you're that one guy on Instagram, I've been commenting on your posts there for a while now
That evo steering wheel looks sick! I need one for mine
