1995 Mitsubishi Eclipse GSX Vehicle Profile & Build Thread
erdman2011's Eclipse GSX
hks blow off valve 3" exhaust big front mount intercooler hks fuel pressure regulator cold air intake 3 guage pillar 16g turbo dsmlink pretty much same for manual and auto both 95 gsx
Mods-Engine
6bolt swap tubular exhaust manifold manual... auto just dejoun piping
Mods-EMS & Logging
ecmlink v2 glowshift digital blue wideband o2/glowshift digital blue fuel pressure/glowshif digital blue oil pressure/glowshift digital blue oil temp/glowshift digital blue boost/ greddy digital boost controller/ greddy digital turbo timer
Mods-Drivetrain
kyb shocks lowering spings for manual... stock on the auto
18" wheels with zr rated tires on manual ...stock on the auto
Parts Wishlist
sheet metal intake/ 70mm throttle body/ 2.3 stroker kit/ brian crower rods je 85.5mm pistons eagle 100mm crank/ acl race bearings/ arp 2000 head rod crank flywheel and rearend bolts/272 cams/ beehive valve springs retainers/ titanium valves/ ported head stage 2/ 1000cc injectors/ aeromotive stealth
1/8 Mile E/T
0.000
1/8 Mile MPH
0.000
0.0 lb/ft
