1998 GSX
- Ownership Status
- Currently Own
- Year
- 1998
- Model/Trim
- Mitsubishi Eclipse GSX
- Turbo Type
- 20g
- Drivetrain
- AWD
- Transmission Type
- Manual
- Build Type
- Street
- Mods-Bolt-on
- 6 bolt swapped, built 20g mitsu turbo (i was told it was built by Justin Whitesell), running on e85, new 2200cc Alpha Injection Injectors, ECU is a dsmlink v3, all emissions stuff gone, 3 inch Apexi N1 Exhaust, OEM exhaust manifold with external WG Flange welded onto manifold, New Tial 38mm WG, Mishimoto I.C, AEM Wideband, Tuned on AEM 3.5 Bar Map Sensor (speed Density). Running around 20 lbs of boost.
- Mods-Engine
- 6 bolt swapped, forged internals.
- Mods-EMS & Logging
- dsmlinkv3
- Mods-Drivetrain
- Need new trans desperately. 4th gear popping out at high rpm.
- Mods-Handling
- Evo Wheels
- Parts Wishlist
- built trans, rebuild engine.
- Background
- Bought it as a non running mess, got it to run pretty good and later found out that compression is a bit low, has some blowby and trans is going out soon.
