1997 Mitsubishi Eclipse GSX Vehicle Profile & Build Thread
DSM NOVA
Ownership Status
Currently Own
Turbo Type
20g
Drivetrain
AWD
Build Type
  1. Street
Mods 2.3 Forged eagle crank
manley forged rods
ross racing pistons .020 over 9:1 compression
1100cc injectors
updated evo style balance shafts with all new bearings
built head with triple seated stainless steel valves
gsc s2 cams
gsc beehive valve springs
gsc no tick lifters
cometic head gasket
arp head studs
kiggly racing oil pressure regulator
evo2 intake manifold (ported and powdercoated by boostinperformance)
1g turbo throttle body (rebuilt by steve monroe from throttlebodys.com)
3" front mount intercooler
PT5858 precision ceramic ball bearing turbo
forced performance intake
ecmlink v3 with boost solenoid
innovate lc2 wideband
innovate mtxd oil pressure and temperature gauge
autometer 30psi boost gauge
snow performance meth injection kit (commanded on by ecmlink)
mishimoto radiator and fans
fuellab adjustable fuel pressure regulator
fic hi-Z 1200cc injectors
deatschwerks 350lph fuel pump
omnipower 4 bar map sensor (car runs on speed density)
transfer case built by jacks transmission (4 spider gear upgrade)
act 3200 6 puck sprung clutch
hks ssqv4 blow off valve
forced performance manifold (ported)
manifold heat blanket
tial f38mm wastegate
jmfab o2 pipe
megan racing downpipe
buschur racing cat back exhaust
gates racing timing belt
fluidampr harmonic balancer
megan racing adjustable upper control arms
megan racing rear strut tower bar
megan racing coilovers.
Mods-Engine
manley forged rods
1100cc injectors
gsc s2 cams
gsc no tick lifters
cometic head gasket
arp head studs
jmfab o2 pipe
  • Like
Reactions: Mikesam
