1995 Mitsubishi Eclipse GSX Vehicle Profile & Build Thread
Street Build
Build Profile of my to be daily driver.
Devilmcponste 95 2ga gsx 400hp daily track stanced
Ownership Status
Currently Own
Turbo Type
20g
Build Type
  1. Street
Mods-Engine
89 6 bolt block, .040 over probe pistons, shotpeen fctory rods, factory crank, knock sensor, gates timing kit/waterpump, godspeed radiator, mishimoto thermostat, 4 ply misc hoses, dks 272 cams, 3 angle valve job, cometic .066 head gasket steel nultilayer, 20g/16gs hybrid mitsubishi turbo with billet internals, DNP turbo header with externl wastegate port, tial wastegate, 70mm s90 throttle body, evo 3 intake mani, obx fuel rail, adjustable cam gears, gates racing timing belt, 70mm intake piping with intercooler to match, 75mm exhaust with vband setup custom downpipe and collector. custom oil catch can and lines, custom oil cooler and lines.
Mods-EMS & Logging
DSM link v3 eprom, hks turbo timer, innovative afr guage and wideband 02,
Mods-Drivetrain
Prothane black motor mounts, skateboard bearings for shifter bushings, crossmember prothane bushings.
Godspeed coilovers, megan racing upper front control arms, new factory front lower control arms, under chassis bracing from the 3g eclipse designed by mochi, rear megan toe arms, rear megan caster arms, 3g eclipse lower and upper control arms, prothane bushings for rear knuckles, mochi rear lower tie bar for the 3g, seam welded the rear subframe. Evo 8 brembo brakes front and rear, ss lines, hawk pads, blackout rotors, Ambit wheels 18x10.5+15
Parts Wishlist
Tires federal 595ss 285/30-18, clinched flares front and rear, eagle talon front bumper, carbonetics eagle talon carbon lip, carbonetics rear hatch with ducktail, megan racing carbon gtr spoiler high rise, status racing seats, rollbar,
Background
Bought car with a blown motor, rusted chassis, bad drivetrain, tore the car down to chassis, and started repairing, welding new sheet metal in, always wanted a gsx and when my buddy couldnt keep it, it was a chance for me to get started in. Car is currently being put back together. Plans are to have a fun decently powered dd. Will attend some track days and autocrosses with the car.
