Please Support Kiggly Racing
Please Support Rix Racing
aovsi's Talon TSi AWD
Eagle Talon TSi AWD
GM MAFT, 510cc injectors, FullThrottle AFPR, AEM fuel rail (with pressure gauge mounted), Walbro 255 lph HP pump.
Galant VR-4 alternator.
Iridium plugs, Magnecor 8.5mm wires, MBC @ 18psi.
3" SS turbo-back (bolt-in cat/race-pipe) w/Thermal muffler.
ACT Flywheel w/ACT 2600--street disk, 4-bolt rear end.
SS clutch & brake lines.
Symborski Shift Kit, Speed-Source trans shift arm kit.
ALL of emissions vacuum spaghetti nuisance removed.
ALL of AC components completely removed.
Mods-Engine
Stock motor internals/turbo.
Mods-EMS & Logging
Digital Tuning Inc Pocketlogger.
2" drop with Sprint springs, with front & rear camber kits, KYB AGX struts.
Front & rear strut tower braces, front & rear poly sway bar bushings. Suspension Techniques 1" rear stabilizer bar.
Exel Mimi 17x7 (+35mm offset, 17lbs) wheels, hubcentric rings, Ventus Sport K104 tires.
Parts Wishlist
Ball-bearing turbo (48+ trim) + all supporting mods.
Quaife center and front LSD in TRE-built transmission.
Kaaz rear-diff LSD.
HKS 264/272 cams.
Fidanza cam gears.
U.R. pulleys.
CF/FB hood.
2.3 L.
AEM ECU.
Aluminum driveshaft.
Fidanza axles.
1/8 Mile E/T
0.000
1/8 Mile MPH
0.000
Timeslip Details
Sponsored Car : no
0.0 lb/ft
Sotarts
Share this Vehicle
