dsm92gsx
- 92
- 0
- Mar 10, 2012
Nampa,
Idaho
92 gsx
all stock except wheels
163k ish miles
17" wheels
So I had my front tires replaced by a local tire shop that swapped the old tires with the "new" used ones and also said they "balanced" them and then put them on. I noticed this happening after the day they got put on.
So driving on the freeway doing 65 mph and my steering wheel starts pretty violently shaking. I can also feel my wheels shaking durin this time. Slowed down to 55 mph and heald the gas, same issue. Went above 65 mph and same issue. So basically from 50-55 mph it happens. Once below this speed it's very lightly happening. It shakes so bad that the whole car is affected. Now when this happens it occurs for 2-4 seconds, then stops for 5-10 seconds, then happens again for 2-4 seconds and so on.
So I jacked up the front drivers side today and shook the wheel and could feel it wiggle back and forth. This is probably the violent shake of the wheels I can feel on the front end.
Does anyone know what this could possibly be?
Tried searching the forums but found multiple possibilities so I am trying to narrow it down if possible.
163k ish miles
17" wheels
