420a non-turbo
- 0
- Jun 13, 2017
Columbus,
Ohio
My engine shakes violently after replacing all my mounts... Is there some kind of after market mount I can add to prevent this? If so where can I find it?
Note: This feature currently requires accessing the site using the built-in Safari browser.
That was my first guess that I made the mistake so when I replaced it again I made sure they were torqued and that's when my intake started unbolting and shortly after the clutch again... Surely a cylinder one misfire cannot be causing that much
You sure the firing order is right? And if it's shaking that bad to vibrate the clutch bolts loose. There has to be some major issue going on either ignition or fuel, related. Any cell on? Could be a bad o2 sensor.
Spyderdrifter. Its good to see you still get on since i last left the DSM scene. Are you still part of that "spyders only" group you started a few years back on this forum? I forgot all about it till i saw your post againSo if your engine was shaking violently before replacing the mounts, your title is completely misleading. That being said, has anything been done to the engine recently like maintenance? How long has this been going on? Did anything major happen right before the shaking started?
Did reinstalling your intake make the shaking go away, or di you put it back on because the shaking loosened it up?
Damn that sucks. I could of probably bought it from u. Whats wrong with your trannyI forgot all about that, so no I guess. I actually sold my spyder last month, sadly, and now I'm dealing with a 99 Oz Edition with a bad auto trans that I can't seem to get to work right.
This crap: http://www.dsmtuners.com/threads/420a-auto-trans-problems.512564/#post-153652294Damn that sucks. I could of probably bought it from u. Whats wrong with your tranny
is the engine leaning towards the cams? Did you level it properly?My engine shakes violently after replacing all my mounts... Is there some kind of after market mount I can add to prevent this? If so where can I find it?
