420a non-turbo
- 0
- Jun 13, 2017
Columbus,
Ohio
My engine shakes violently after replacing all my mounts... Is there some kind of after market mount I can add to prevent this? If so where can I find it?
Note: This feature currently requires accessing the site using the built-in Safari browser.
Damn. It sounda likr the owner before you uses the wrong atf and destroyed your clutch packs. Thats why u have to rev it high just to get any engagement. I would just recommend a manual swap. Where do u live im down to help if your in the same state
Nice, the best part is that your close to jackstransmission. And i say a manual conversion would be better. If your interested i have a FWD transmission just laying around sincei did the awd conversion on my spyderWell, I do believe the wrong fluid was used by the PO. I also ended up using the wrong atf when I replaced the torque convertor, but I was using what the owner's manual stated. Didn't know at the time that ATF+4 was the only atf to use. But it's got that now, and it seems ok in the forward gears, but reverse barely works. My best guess is either the solenoid pack needs a rebuild (or just a new one), the atf is still at the wrong level, or something else I can't even see. When I replaced the trans pump,I did take the time to inspect the gear sets and clutch discs. Everything looked good. I was surprised to see that since I did have one dtc saying there was mechanical failure. But, it looks like the manual conversion may happen. I still live down in Springs btw.
Is anything leaning against the cams it may of thrown off the timing and is creating high pressureMy engine shakes violently after replacing all my mounts... Is there some kind of after market mount I can add to prevent this? If so where can I find it?
Just yesterday i helped an older couple move their car. Apperently the same thing happen. Her car was stuck in the middle of the highway. You can get in a terrible accident with that.That would be awesome. I did find someone parting out a red Talon on craigslist and sent 2 emails just to get no reply. Thanks again.
My car ended up here after the transmission locked up while I was heading to work. Once I finally slowed down and managed to stop, I couldn't push the car (yes, it was in neutral and parking brake off). Once a friend showed up to help, it wouldn't even move well with her pushing with her truck... so I'm done with this auto trans.
