Brake indicater lght on
chiuchimu
94
3
Jun 25, 2008
Sylmar, California
for a year now, my brake indicator light(warning light) on my dash board is on all the time.
I haven't repaired it until now because the brakes work fine. My car starts up fine, runs fine and has been doing so for a year with the brake warning light on.
Given that:
my brakes work fine
My hand brake works fine
My alternator is fine
Brake fluid level is fine
What can be the cause?
There is a separate light for the abs system. If it is just the e-brake low fluid indicator light than there is a fault with the switch or sensor in the fluid reservoir. I would check the sensor on the e brake assembly first. That is the most common.
I agree, sounds like the e-brake warning switch being faulty which is located under the center console. Or it could be the low fluid level indicator switch, which is located under the brake fluid reservoir.
