Activity Feed
Live updates
  • Back from the track and good news to report.We didn't quite hit the 9 I was shooting for but settled for a SOLID 10.2 @ 146.9ALL of my passes besides the last 2 had issues with boost cuts due to hitting my boost cut safety @ 50psi. It was...
  • Badge023 replied to the thread Pet peeve.
    · 18 897
    That's a standard option on Dodges.
  • Detail replied to the thread My other daily driver!.
    · 76 7,232
    My AC is empty. It is crazy hot. Trying to find somewhere local to rent/borrow some dry nitrogen to pressurize and find my leaks. So far, no luck.
    · 76 7,232
    Got inspired by a lot of you all and decided to have a go at lowering iat’s. Had to learn CAD. Cardboard aided design!You must be registered to see element.Used some of the left over plastic from the ducting, my new gearwrench rivet tool...
    · 76 7,232
    That didn’t turn off the low oil pressure light. Ordered a new oem sensor. Very thankful that seemed to “fix” the issue.You must be registered to see element.
    · 76 7,232
    My car has been leaking oil in the street every day. The custom oil cooler lines I originally fabricated from the hydraulic store just were not working. Few conversations with the robot and I went and made a purchase at pegasus racing. Highly...
  • athlete3344 posted a question on the classified ad Wanted 1g 6bolt Balance Shaft.
    I might but im pretty sure its also marred. It was used to drive in new bearings. Ill find it later tonight and send you a pic.Ironically, the classified ad below yours is a set of new bearings and stub shaft. I'd delete tbh.You must be...
  • 1990TSIAWDTALON replied to the thread 'Disappointment in a box'.
    · 8 596
    I have to give my condolences also 🙏 You will have grandpa's cars history. As a "car" guy, that means something. 🥰
  • athlete3344 replied to the thread Pet peeve.
    · 18 897
    Lifter tick....change your oil!
    · 76 7,232
    June seriously tested my patience. Front axle boot got miraculously torn…DSM‘s. Its always something! You must be registered to see element.
  • athlete3344 replied to the thread Long awaited decade long project.
    · 35 4,242
    Oo thats a good idea with the washers! Definitely bending that arm and someone else mentioned in a pm that I could probably swap the actuator arm or the hex connection from the t25 since its a bit bulkier and more material around the connection...
    · 76 7,232
    You must be registered to see element.So after all of that was installed, I had the car towed to Gran Turismo East in Atlanta. Going to fast forward 3 weeks and $1500 later…and I got the car back. It is aligned to the specs John at Mullerized...
    · 76 7,232
    So anyways. Got to trying to film the front install. It was a lot. Volk lower arms, FIBA upper arms, and the coilovers. Well turns out you have to open the oem shock mount holes a hair to allow the ohlins to fit. A simple round file and a few...
  • jesse12345 replied to the thread 98 Eclipse GS high school dream build.
    · 45 3,606
    I literally couldn't help myself, I started digging in on the drivers front. If I'm not going to drive the car this year I might as well get a head start on the rust repair. I usually don't get lucky with some light rust here and there, it's...
  • Justin DuBois replied to the thread Long awaited decade long project.
    · 35 4,242
    Space - The question of fitting is usually about the space needed. Banjo fitting are great for 90deg direction change cause the fitting takes less height.
    · 76 7,232
    It’s been a super busy past few months. Shot some content and ended up simply giving up on editing some other stuff. Work is just crazy busy.Here is the rear Ohlins install video. They were pretty straightforward even though I did them sans...
    · 35 4,242
    You may want to bend the bracket, or add washers under one of the feet to help point the arm
  • Can I turn off the p0300 with that
  • DSSA replied to the thread 'Disappointment in a box'.
    · 8 596
    Then it was this thread..
  • deexeq replied to the thread General MMCd-Go.
    · 9 979
    Hi everyone! I managed to get the machine working with the program. I had to replace the adapter with a different one featuring the original FT232RNL chip and slightly modify the wiring diagram. Once again, a huge thank you to the author for...
