Activity Feed
Live updates
  • eddyspaghetti replied to the thread 2G I think my crank timing is off?.
    · 55 2,117
    So this is where the marks ended up after tightening , I think they're in the correct place?Also, when you say backwards, do you mean upside-down or do you mean the outside has to be facing the inside?You must be registered to see element.
  • tschuhly replied to the thread 2G stuck in limp mode.
    · 81 3,360
    So based on what I read I ended up double checking the BW wire at the ignition switch plug when the key is ON and I was getting 12v from that. I then probed pin 82 at the ECU with the key on and got 0v. I am thinking that this means that I have...
  • Wun-jee Claud replied to the thread What did you do to your DSM today?.
    · 12,120 840,495
    I have solid mounts and broken clip for that sensor... Took a pair of needle nose pliers and put some hot glue on the ends of the pliers and gently forcefed that clip back into place... Just got back from a spin and it stayed off.... Felt as if I...
  • DSMPT replied to the thread 2G I think my crank timing is off?.
    · 55 2,117
    Yes, just move by a tooth counterclockwise but "without the belt".No, they won't.Right. But he is using a cam gear lock tool.Is this after putting the tensione?BTW, I found the balance shafts belt tensioner pulley is installed backwards...
  • James92 replied to the thread What did you do to your DSM today?.
    · 12,120 840,495
    I need to do something similar, it’s nearly the final part I haven’t touched on yet. Hesitating hard on pulling the dash out because I KNOW I’ll spend weeks obsessing over it. ———— To update on my rear brakes I got everything put on, the pads are...
  • jdxnc replied to the thread What did you do to your DSM today?.
    · 12,120 840,495
    Made it out to another event with the car this weekend, battled some issues but finally making headway.Saturday it would not make anymore than wastegate pressure(18 psi), made 3 passes in a row right around 10.70 @ 120....almost a perfect...
    · 55 2,117
    Another pictureYou must be registered to see element.
  • RamenPride replied to the thread 2G I think my crank timing is off?.
    · 55 2,117
    The exhaust cam tends to rotate counterclockwise when tension is applied to the belt. You can advance it one tooth clockwise before applying tension and it should line up. Try setting the crank mark and then the cams instead of locking the cams...
  • Vladimir replied to the thread Resolved 2G A/C system not working.
    · 161 5,558
    Ok, great. We might have located the main issue. Please don't try to hardwire anything in yet, we will do more testing because there is so many variables that are still unknown. I'll get back
  • cswindel replied to the thread Resolved 2G A/C system not working.
    · 161 5,558
    Yeah there is no pin 42...the more I have troubles with this harness the more I hate how much money I spent
  • steve replied to the thread Throttle shaft cleaning - remove this rubber?.
    · 3 648
    Did you ever figure this out?
    · 55 2,117
    So because my cams are locked in correct order, I can manually turn the crank to its mark and not risk damaging the valves? Please helpSo I just moved the crank counter clockwise just a bit, the engine didn't fight me, I was able to move it...
  • steve replied to the thread What did you do to your DSM today?.
    · 12,120 840,495
    So inquiring minds want to know what was the fault code the ECU is whining about?
    · 161 5,558
    Good. Almost zero resistance indicates that the pressure switch made circuit. It sees the pressure and work as intended.We will continue. Just give me some time. I'm doing gigs againAlso if pin 42 wire is missing the a/c clutch will never get...
  • Got mine in mail today. Xtra clearance bearings ordered as well, on back order. Thanks Josh (JNZTuning) and King Racing!
    · 161 5,558
    Well it looks like they did some weird stuff again and left out a wire for pin 42 but I have 22 and 45 with 45 having 2 wires. 22 does have continuity with the relayYou must be registered to see element.Im reading 0.04 ohms on the pressure...
  • jersygsx posted the classified ad For sale 2g 2G FMIC Setup in DSM Parts Classifieds.
    2G DSM FMIC Setup $375 + shipping & paypal feesDimensions * 29” end to end * 11” tall * 3” core * 2.5” Inlet/Outlet* BOV flange is Greddy style, I have a generic BOV I can include as well if neededYou must be registered to see element.You...
    · 161 5,558
    Ok. I'm sure that there is gonna be a problem with the wiring controls just because your condenser fan is not kicking ON and you say that there is actual power being present at the connector for the press switch. With a/c ON as far as you know...
    · 12,120 840,495
    Put in a new radiator today... Then poof check engine light came on...only difference the sensor port used to be brass.. on the replacement it's plastic... No other changes...You must be registered to see element.You must be registered to see...
  • steve replied to the thread 2G My scan tool and my DVOM disagree..
    · 12 756
    Here's the deal. If your ECU is activating the CEL and reporting an problem with the voltage it would be worth chasing this but I'm not sure there is anything other than a voltage drop to the port and some unknown wire connected that is giving...
