Activity Feed
Live updates
  • avaughan89 posted a question on the classified ad For sale 2g 1995 eagle talon.
    Hi, I realize this listing was posted some time ago, but is the 1995 Talon TSi AWD still available? If so, could you confirm the current mileage, transmission type, mileage on the engine build and whether you still have the complete machine-shop...
  • 92PLazer replied to the thread 1G F4A33 Transmission Issues.
    · 9 461
    Before we continue, huge thank you for the quick response and helpful insight. You guys rock.Following Brandon's advice, I removed the end clutch housing. Looked pretty normal although the nasty oil is very present. A little worried about what...
  • Ludachris replied to the thread 2025 Shootout Competitor Entry Thread.
    · 36 3,051
    So if we have to choose a class for this donation to go to, which one would you guys think it should go to?You must be registered to see element.I know we can't guarantee it will go to a DSMer, but it would be nice to choose a class that has...
  • Thank you so much,That helped me confirm the GSX has a different trunk board than my GST. The design, size and maybe the location of the hooks, is different.I just found this that helped me confirm everything. You must be registered to see...
  • SixBolt_16G replied to the thread 6266 Build or Bust.
    · 724 76,674
    Soooooo.....Did you get to drive? How was it?
  • SixBolt_16G replied to the thread 2G BMW seats?.
    · 2 290
    Nice! Do the seats sit higher/lower than stock? Im tall, so always concerned about head room.
  • dwb posted a question on the classified ad For sale 1g ACT 2600 PP + street disc.
    Is that disc cracked or is it just a hair or something on it? Hard to tell, but not uncommon for an ACT. It's in the pic showing the yellow side of the PP. Top spring in the disc, just to the right.You must be registered to see element.
  • Have these mount brackets as shown. Let me know if your project needs any of these.-GVR4 front roll stop bracket 344-1G turbo FWD 5 speed transmission bracket-1G turbo AWD 5 speed transmission bracketI put $40; I'm thinking that is...
  • SixBolt_16G replied to the thread 420A Help with good brake pads/rotors replacements.
    · 27 1,021
    I was happy with Powerstop pads... I currently have Porterfield RS-4 that i had in my garage forever. Probably the least amount of brake dust ive ever had, but havent been able to get on it enough to give you a solid review of them. Im pretty...
  • ItsTwan309 posted a question on the classified ad For sale 1g 1991 Eclipse GSX.
    Great looking car, and the bay looks clean and simple! GLWS
  • pma1123 posted the classified ad For sale 1g ACT 2600 PP + street disc in DSM Parts Classifieds.
    This ACT2600 was installed new in my Talon. Use was street driving/never drag raced. Lots of miles left in it. My car made 242 AWHP and I mostly drove it in the snow. Paint all scratched up because I was swapping around grinding/abused...
  • Raider_831 replied to the thread 420A Help with good brake pads/rotors replacements.
    · 27 1,021
    Thanks for the suggestions, those have been good for you in the noise department as well?I did upgrade to stock 5 spoke oem Eclipse rims, but no I don’t plan on doing any swaps to GSX or outlander brakes. I just wanted to get some solid...
  • dwb replied to the thread 2G stuck in limp mode.
    · 80 2,920
    That's exactly what I did! :thumb:
  • tschuhly replied to the thread 2G stuck in limp mode.
    · 80 2,920
    I did have the coolant lines. As far as I have researched, I will want to tighten the FIAV spring all the way down, cap off the coolant line on the FIAV side of things and then loop the coolant line from the therm housing down to the heater pipe...
    · 27 1,021
    If youd like to take it a step further, you could get the GSX calipers, which is a dual piston compared to your single piston, with Outlander brackets which would allow you to use the larger Outlander rotor.You must be registered to see...
    · 80 2,920
    More than likely your FIAV was at least partially stuck open. Did you still have coolant lines hooked up to the TB? Now that you closed off the FIAV, you will want to loop or cap those lines.
  • Xarzor posted a reply to a question on the classified ad Wanted 2gb OEM front bumpercover.
    Eclipse
  • steve replied to the thread General 1g 1990. IC106 exploded.
    · 5 374
    IC106 is for the Wastegate (Boost Control) and Fuel Pressure solenoids.Is that wire loose in you first picture and you've connected it in the last or the other way around? I'd have to look at a 90 ECU to be sure of where the wire is connected...
  • dwb replied to the thread General 1g 1990. IC106 exploded.
    · 5 374
    This is about all I know about it, and I'm hoping you have seen this page already. You must be registered to see element. "IC106 controls ECU pin 57, Fuel Pressure Solenoid (FPS), and ECU pin 105, Boost Control Solenoid (BCS)." I guess you could...
    · 80 2,920
    Alright, still haven't heard from my tuner so I have been looking into stuff myself and want the experts opinion to see if I am thinking correctly.As Steve pointed out prior my ISC is at 90, so I adjusted that down to 40ish (I have 272 cams). I...
