Activity Feed
Live updates
  • MikeyTsi posted a question on the classified ad For sale 1990 Plymouth Laser RS 2.0L.
    Is this turbo? AWD? Would probably be helpful for folks if you posted a picture of the engine bay as well so people can see condition.It's nice seeing a Laser that's had so much love, so rare seeing one in good condition these days.
  • 1cleangsx replied to the thread 6266 Build or Bust.
    · 724 76,813
    You must be registered to see element.So here’s the fitting that was leaking, it now has a O ring which it didn’t before, I can’t remember if the other side had one or not, I’m not cracking it loose to check because it’s NOT leaking lol, so as of...
  • jersygsx posted a reply to a question on the classified ad For sale 2g 2G Manual Shifter Cables.
    Yes sir
  • GIB replied to the thread 2G First Gear Pops Out.
    · 57 2,924
    I shifted it into first. It did not move more. The cable may be loose, it did have movement, but I'm not sure it it is normal play. The cable for 2 and 4 doesn't move nearly as much when I try it. Its been like this for about 5 months. Shifting...
  • dwb posted the classified ad Wanted 1g WTB: OEM harmonic balancer (crank pulley) in DSM Parts Classifieds.
    Before I go spend $300 on a new one, does anyone have a good condition OEM harmonic balancer/crank pulley you're willing to sell? Something better than the one pictured. I'm pretty sure any model year works, but it will be going on a 91 6-bolt...
    · 724 76,813
    So I just got another 1/8” turn or so, she’s bottomed out tight, still leaks on that end lol, so looks like I’ll be replacing the fuel filter :idontknow:
  • jesse12345 replied to the thread 98 Eclipse GS high school dream build.
    · 45 3,358
    If you dont think it's to bad maybe ill ride it out for awhile. Ill have to see how it feels first. I do like having all of the power steering mess out of the way.
    · 724 76,813
    Well guys no first start today, after a couple 5 second starter bumps and looking around/underneath the car I discovered 2 fuel leaks.You must be registered to see element.The worst one was at the outlet end of my fuel filter, I remember that...
  • miliman13 replied to the thread Long awaited decade long project.
    · 35 4,141
    Sand blasting is gods gift to man kind 😂No but it’s really helpful, but the sand getting everywhere 😷!!!! (Open air)Post more !!!!!!!!!!!!!!!!!!!
  • miliman13 replied to the thread 2G First Gear Pops Out.
    · 57 2,924
    Im sure you are well aware, but incase; don’t forget you need the“extenders/ adjustable end links “Without them the K series cables are too short and will lead to the very same problem you are having.The cables need to be in compression...
  • 99dsmer4g63 replied to the thread 2G First Gear Pops Out.
    · 57 2,924
    How much movement does your engine have? Are your engine mounts clapped out?-Daniel
  • pauleyman replied to the thread 2G First Gear Pops Out.
    · 57 2,924
    If you are convinced it isn't the trans then there is still something misaligned in the shifter assembly. Shift it into first with the shifter then go to trans an see if you can push it more. If you can, then look for the slops, adjustments...
    · 57 2,924
    *Update. I installed, MIT-MB307949 (shifter cup bushing), MD712919 (Transmission gear selector shoe), polyurethane bushings for the shifter assembly, and the White Shed Speed shifter cable bracket to replace the two MD723290 (shift cable bracket...
  • FIBA M - EC17PSE replied to the thread 33rd Annual The Shootout 2026.
    · 22 1,187
    Got mine all setup and ready!You must be registered to see element.
  • 19Eclipse90 replied to the thread Resolved Throttle body Bolt pattern..
    · 4 3,683
    Can confirm as well. The difference of 0.008” there isn’t going to make much difference from being “square”.For what it’s worth, I’ve measured and have based my models off a 2.520” square pattern (64mm x 64mm). Since it’s a Japanese engine...
  • Dannyrampage1 replied to the thread What did you do to your DSM today?.
    · 12,065 830,684
    I guess it should not be difficult to get a replacement foam filter maybe not Mitsubishi OEM but something similar like maybe Lowe's or home Depot and just cut it
  • Drewpy Dawg replied to the thread What did you do to your DSM today?.
    · 12,065 830,684
    I have. I did a complete restoration of all the HVAC boxes behind the dash. They're not really filters, just foam that seals up the doors. I assume yours have turned to dust like mine had? I don't have a write up on it but I took a bunch of...
  • I had Haynes Engine Works do some work on my 6 bolt block.Oil clearances were dead on spec, ptw was very consistent over the length of all 4 cylinders, rings gapped correctly, everything was balanced within a gram or 2. They even removed a...
  • athlete3344 replied to the thread Long awaited decade long project.
    · 35 4,141
    Last time I was sandblasting parts, it was in a homemade cabinet that is no longer with us. Replaced it with a Harbor Freight model and its getting the job done 10x faster.Sandblasted a bunch of random motor stuff and started painting parts...
