Activity Feed
Live updates
  • TasosEclipse replied to the thread 2G Oil leak.
    · 80 2,656
    I checked the valve it moves like you said
  • Anfurnyy replied to the thread 2G Oil leak.
    · 80 2,656
    Okay and what about the other line with the check valve? You'll have to take it off and blow through it from the valve cover side and it should go through. Then blow through the other side and make sure it DOESNT go through. It's only meant to...
  • steve replied to the thread Resolved 1G DSM MPI relay or ECU problems.
    · 8 512
    Gosh that is ugly. I've seen a few like that and always wondered how they would get that dirty and still be "repaired". However I've been around the block a few times with this poster and I don't think there is much I can add that I haven't before.
    · 80 2,656
    No
    · 80 2,656
    Goes to atmosphere? It doesn't connect to anywhere on inlet to the turbo?
    · 80 2,656
    The pcv goes to intake like stock and the other one goes to atmosphere
    · 80 2,656
    Where do both of these lines connect to? You must be registered to see element.Can you remove the check valve on the blue line and make sure it only blows out and not back in?
  • dwb replied to the thread Resolved 1G DSM MPI relay or ECU problems.
    · 8 512
    @steve might be able to see something on that board, but it's definitely a suspect imo.I think the tale tale sign here is the issue disappears with another ecu. Unless you have an intermittent broken wire, what else are you touching when...
    · 80 2,656
    Here is a photo from the headYou must be registered to see element.
    · 80 2,656
    Fix your PCV stuff and stop recirculating your crankcase vapors if you can.How is your PCV stuff hooked up?
    · 80 2,656
    And what you suggest I do?
    · 80 2,656
    Crankcase pressure. Pretty much the only reason.
    · 80 2,656
    You must be registered to see element.I took off the charge pipes and here is the oil why there is oil on a new turbo ?
  • Tommytmopar posted the thread Radio diagram in Maintenance & Repairs.
    Who needs a diamond star radio diagram? I got one if you want it lmk. Don’t won’t it to go to waste. Tommy
  • sakroda replied to the thread Resolved 1G DSM MPI relay or ECU problems.
    · 8 512
    I realize that my soldering is not well:( I have socketed by myselfYou must be registered to see element.You must be registered to see element.You must be registered to see element.You must be registered to see element.You must be...
    · 8 512
    I assume you swapped pins 6 & 14 on the ecu harness for the 90-91 conversion. Do you see the check engine light for a few seconds after turning on the ignition? Have you checked out the capacitors and board on the 91 ecu for leaking and...
  • pma1123 replied to the thread Resolved 1G DSM MPI relay or ECU problems.
    · 8 512
    Show us some pics of the ECU boards; this MPI clicking stuff sounds a lot like erratic behavior with leaking power filter capacitors. If your car has been working great on a 91 ECU for a while till recently, I'd start there.I'll let others...
    · 80 2,656
    What you recommend to adjust?
  • dwb replied to the thread 2G Oil leak.
    · 80 2,656
    High crankcase pressure is still a real possibility. Lots of excellent recommendations in this thread already so I won't beat that horse. It's up to you to follow through the suggested procedures. If you have questions we're here to help.
  • DP_52 replied to the thread ECMlink First post! ECU question.
    · 50 2,253
    Pretty sure it’s the 95/96 CAS. I ordered the cable to run DSMLink and see what settings it is on.The car will run rough with a stock ECU in it, I’ll swap the injectors to the 450cc ones I have and make everything as stock as I can
