Activity Feed
Live updates
  • enriquez2000 replied to the thread Street Build Resurrection of the Red 90 Talon.
    · 849 81,065
    What other issues?
  • Hey guys I'm having a issue with my 97 Eclipse GSX. So I recently had my transmission replaced along with brand new clutch and flywheel but ever since I've got the car back my car won't roll in neutral. I was hoping anyone might know what can be...
  • jesse12345 replied to the thread Built 420a Eclipse (98 Eclipse GS turbo).
    · 26 1,530
    So I've been grinding stupid hard on the car this past week. I got all of my rear suspension how I want for now. The rust is not fixed since I'm just focusing on getting everything else straightened out for now.The engine is finally all put...
  • 1990TSIAWDTALON replied to the thread So what are you working on that’s NOT your DSM?.
    · 1,706 134,447
    Predator motors have worked for us time and time again!
  • 1990TSIAWDTALON replied to the thread What did you do to your DSM today?.
    · 11,948 763,488
    I went to a local get together in the town south of me 15 minutes. I had a few issues, but the car RAN great and she got me back home 👍 Typical DSM stuff but got me back home.You must be registered to see element.You must be registered to see...
  • xn35 replied to the thread Resolved Clutch Drag Gremlin.
    · 29 2,015
    I just want to add that when welding the pedal it is important to weld it in the position with the slack out of it. My experience is if you weld it in the worn position you probably won't get much help with the master. I'm not sure why this isn't...
  • 1990TSIAWDTALON replied to the thread Street Build Resurrection of the Red 90 Talon.
    · 849 81,065
    It is still the tune we were working with @enriquez2000 👍💯 and thank you, it's not bad at all. The car gets outta town once the turbo lights. 😊The Meth is working now. Tested tonight but no log because of other "issues" :(
  • 92AWDHX40 replied to the thread Norwalk or bust 2026..
    · 406 59,543
    Change is good no more red brembos. Need to get black decals now and clear coat.You must be registered to see element.You must be registered to see element.
  • DreamChaser7 replied to the thread So what are you working on that’s NOT your DSM?.
    · 1,706 134,447
    Figured I’d better oil and gas up the new genny and get ready for hurricane season. The old one just wasn’t big enough…You must be registered to see element.
  • 92AWDHX40 replied to the thread Street Build Resurrection of the Red 90 Talon.
    · 849 81,065
    I havent seen a link long in over a year, haltech is definitley different its i guess ill get used to it once its running. Good numbers
  • SixBolt_16G replied to the thread What did you do to your DSM today?.
    · 11,948 763,488
    ...and just like that...You must be registered to see element. Not sure where the other one shot off to.. So my magic trick seems to have been spraying this on both sides and using the chain breaker. You must be registered to see element...
  • Raider_831 replied to the thread 2G Fuel Pressure Solenoid.
    · 12 4,617
    It just didn’t make sense why on eBay it says it doesn’t fit my 97 GST. I guess I’m just overthinking it and eBay is wrong with their fit compatibility, Thanks for clearing that up.
  • 19Eclipse90 replied to the thread 2G Fuel Pressure Solenoid.
    · 12 4,617
    MD113721 is the fuel pressure solenoid part number found in 2G turbo DSMs.I’m not sure how this thread could be any clearer.eBay is not what I would consider a reliable source for parts cross-compatibility.
  • Jeff D replied to the thread 1G Talon.
    · 52 4,130
    You must be registered to see element.Ended up just painting these parts over powdercoating as my oven setup had some issues. Anyway new wheel bearing in the driver side spindle and pressed the hub back on, I was really torn whether or not to...
    · 12 4,617
    Hello sorry this post is a bit confusing for me. I have a stock 1997 Eclipse GST Spyder. I currently have code p1105 which indicates faulty fuel solenoid.Can someone confirm which part number I need? I tried putting the MD113721 part on eBay...
  • We're on Boost replied to the thread Street Build Resurrection of the Red 90 Talon.
    · 849 81,065
    Marty it looks like you went another 500 rpm or so farther before shifting, and the boost held up during that time, and the airflow line goes off scale so we can't see it. What did the airflow get up to in there? The knock that you are wanting...
  • RamenPride replied to the thread 2G Throttle Body Sticking.
    · 30 1,118
    Don't mess with the throttle stop if it was fine before taking it apart. I would guess the nuts on the shaft are still too tight. I had the same problem on the last TB I rebuilt, and loosening them was the only thing that fixed it. They don't...
  • MHumphrey22 replied to the thread 92 Talon TSI AWD.
    · 3 236
    Installed some of the rear plastic and rear speakers last night.
  • 19Eclipse90 replied to the thread Spyder Interchangeable.
    · 2 147
    I imagine the OP is asking about the window switch bezel which, almost certainly, won’t be found new anywhere.OP, you can try this avenue:You must be registered to see element.
  • FIBA M - EC17PSE replied to the thread 2G Throttle Body Sticking.
    · 30 1,118
    I only see 1 spring latching onto the arm. maybe the video was not clear for me to see it correctly, I just see the green one lol
