Activity Feed
Live updates
  • ItsTwan309 replied to the thread 2G 420A Voltage issue maybe.
    · 9 602
    Looks like your injectors will be fine much lower. Yeah sand bare before the screw, and extra credit for dielectric grease. make sure you have all your engine grounds as well. Its huge, I was missing a few haha
  • midfb6 replied to the thread 2G 420A Voltage issue maybe.
    · 9 602
    ill look into my grounds i did repaint the engine bay and some threads has some rust in them tho i did my best to clean them , durning datalogging i dont see my injectors having anyissues or going lean up top in rpms
  • ItsTwan309 replied to the thread 2G Throttle Body Sticking.
    · 30 1,506
    Needed a Pro in here to shed some light! :D
  • FIBA M - EC17PSE replied to the thread 2G Throttle Body Sticking.
    · 30 1,506
    What you have is the shaft nuts too tight and not central either. Once the casting warms up it expands a bit and jams. I have had this before and was 1/4 nut turn too tight lol small amount bit jams it.Can check that and it is central with a...
    · 9 602
    As long as its not running lower than Injector voltages. I will say when I replaced all my grounds, My voltage went up by .6.
    · 30 1,506
    Not sure on if you can overtighten those. I do have the experience of having my stop set wrong and sticking closed as well as being hard to start open. Did you mark your springs before you took it apart? I doubt this would cause anything, just...
  • ItsTwan309 replied to the thread 2G 2G GST smoking after 6 bolt swap.
    · 22 1,164
    Did you get around to checking the AFR?
  • kyler021 replied to the thread 2G Throttle Body Sticking.
    · 30 1,506
    Wow it would've been helpful if I included that in the original post haha, but when it sticks it'll stick slightly open. So it'll rev up to like 2000-2500 and stay there.I am looking at videos and pictures again, and it looks like everyone puts...
    · 9 602
    during a pull at 75% throttle 4000 rpm it stays at 13.4 maybe goes to .5 or .6 but its consiestantly on 13.4 for the main part of it
    · 9 602
    It should be atleast 13.8 or higher. How is voltage during a pull? My car is like 14.2-14.6 with lights and fans.
  • ItsTwan309 replied to the thread ECMlink BoostEst not matching Gauge.
    · 4 408
    its about 4 off give or take
    · 30 1,506
    So it wants to stick closed? If so, is your throttle stop set to low?
  • Hey all,I recently rebuilt my throttle body with new shaft seals and a FIAV delete, and now my throttle plate seems to stick. Seems simple, but the weird thing is it only sticks when the engine is turned on. I can't get the throttle plate to...
  • S'tan replied to the thread 2G 2G GST smoking after 6 bolt swap.
    · 22 1,164
    Thanks for the info. I will give that a try. Hadn't thought about the rings needing to be seated. I was just concerned about getting pulled over due to the smoke or something potentially getting damaged
  • pma1123 replied to the thread PMA1123's Talon.
    · 28 2,587
    Without trying to make this a multi-page thread about gas tank cleaning pictures; these pics were after Round 1 of nails, gravel, E85 and lots of shaking.The bottom of the tank is pretty clean, the varnish residue is still along the sides and...
  • Justin DuBois replied to the thread 2G 2GA headlights.
    · 4 269
    Everything said is correct. What do you want it to look like? 95-96 2Ga Eclipse? - or a 97-99 2Gb Eclipse? The fog light brackets and front air ducting are setup for a 2Ga "smiley" bumper cover and headlights.If you are switching the body...
  • Tiki2777 replied to the thread 1G AFPR Return Air.
    · 2 276
    I don't even understand what you're trying to test. The AFPR is the clamp in the system that sets the pressure, and the diaphragm/spring combo allows the pressure to vary up/down with the reference air source.Have you tested the fuel system...
  • Justin DuBois replied to the thread 2G SRS diagnostics today.
    · 15 854
    No, 95 GSX had two connections, Drivers seatbelt and power for the position adjustments. I don't even think the passengers belt is wired.
  • midfb6 posted the thread 2G 420A Voltage issue maybe in Electrical Tech.
    Car runs and drives at 13.4v might go to 13.5/13.6 once or twice will also idle at 13.3/13.4v Under load at 4000rpm it stays at 13.4 volts. When i turn my rad fans on i see slight drop to like 12.7 then it shoots right back up to 13.4. My 13.4v...
  • Moidsm posted a reply to a question on the classified ad For sale 2g 7-BOLT CRANKSHAFT (UNCUT).
