Activity Feed
Live updates
  • DSMHERO1 replied to the thread 2G '95 MPI/Fuel Pump Failure?.
    · 18 577
    I couldn't really make out the markings. It looked like one was marked North/South and the other East/West.The belt didn't completely snap. It does have a tear going long ways with visible shredded fibers. I'll try to post a picture tomorrow...
  • pauleyman replied to the thread 2G '95 MPI/Fuel Pump Failure?.
    · 18 577
    You wont know until you check mechanical timing. If its way off yes you likely bent valves. If belt is broken its practically 100% certain.
    · 18 577
    So, I got the car home and got a better look. I knew I had to be missing something and I missed a big thing. The timing belt has a tear in it. I'm not sure how I missed it. Maybe it was just exhaustion.Could I have caused damage to internals...
  • pauleyman replied to the thread 2G 95 Eclipse GSX questions.
    · 36 1,638
    If you haven't had the deck surfaced shop towels won't get it. Yes it will degrease it but it won't touch the old gasket and there is likely a lot more there than you realize.If your deck doesn't look similar to this, it isn't clean.You must...
  • Lintu replied to the thread General 95 ECU power pins test.
    · 15 941
    What is the ECU part number? MD30xxxx.Bypassing the clutch switch was a smart move!I don't think you'll see much with a multimeter on the OBD pins, especially pin 62, since it carries serial data. (With an oscilloscope, you should see digital...
  • TheBrownMike replied to the thread Street Build She's A Keeper.
    · 46 9,292
    Well I finally had good chunk of time off to finish building the motor, and get it swapped over. I understand why things take so long now, with work, a baby and various other to-do's, but finally got it fired up today. There were a lot more...
  • Discontinued MD122260 Forward Facing Oil Filter Housing This one has a dent (no crack) i just test it on my own car for about 100 miles and no leaks! $150.00 shipped plus paypal fees if you have any question please let me know!You must be...
  • GIB replied to the thread 2G Antilock light flashing, no interior lights, etc.
    · 3 235
    I checked all of the fuses and wires. I started to wiggle the fuse around and now everything turned on?! ? Maybe there is a short ?
  • BrandenB replied to the thread Eclipse GST.
    · 8 1,121
    Well since I have done this I’ve had a vacuum cap come off a few times. So just make sure you secure them down with a zip tie or tiny hose clamp. Otherwise it’s pretty simple and straight forward to do. I followed a video I found on YouTube. I’ll...
  • Nofclue posted the thread 97 Eclipse GS in DSM Build Journals.
    This is the Build Thread for You must be registered to see element.. Reply below.
  • Nofclue added a vehicle profile titled 97 Eclipse GS to the 2G DSM section.
  • 19Eclipse90 replied to the thread 2G 95 Eclipse GSX questions.
    · 36 1,638
    Here’s the cylinder head bolt installation sequence snippet from the service manual for 7-bolts:You must be registered to see element.Do note #1 is on the exhaust side (top of illustration).Yes, shop towels and brake cleaner are okay for...
  • A plastic welder, used correctly, would fix a Crack. Use some ABS Cement to overlay it after trimming the welder zigzag things tabs, and it should hold fine. I just patched a ATV fender with mine. Good luck! ✌️You must be registered to see...
  • 1990TSIAWDTALON replied to the thread 420A Pls help no start after transmission swap.
    · 8 288
    Also check firing order. I know its a no brainer, but sometimes the smallest thing is the culprit. Make sure you ARE GETTING SPARK. Good grounds to the engine are super important too. Just tips.
  • dsmcrzy replied to the thread dsmcrzy's Eclipse 20g 420a.
    · 320 77,812
    What is a DSM without needing something constantly? So I drove it to work the one day for a car show. Then saw I was leaking brake fluid near the brake fluid reservoir. Ordered some parts and got that fixed up today finally and bled the clutch...
  • CrazyDave replied to the thread 2G No crank no start.
    · 14 500
    If the spark plugs are removed and you feel a "hard" spot while turning that isn't good at all. Rod is probably broken and valves are probably damaged. Time to pull the engine
  • AgustinGSXTribute replied to the thread 2G 95 Eclipse GSX questions.
    · 36 1,638
    I'm reattaching my cylinder head and wanted to know if this is the correct sequence for tightening, and if it's okay to use shop towels and brake cleaner to clean the surface of the short block?You must be registered to see element.
  • 19Eclipse90 replied to the thread 1gb laser taillight options.
    · 1 145
    Eclipse tails are 100% a direct swap, 1Ga or 1Gb. 1Ga Talon tails are a direct swap.
  • Grd1043 replied to the thread 1992 Eagle Talon TSI AWD.
    · 22 1,316
    I did a compression test before we pulled the engine, I was seeing about 140PSI on all four cylinders, plus or minus about 3-5 psi
  • Xyloren replied to the thread 2G No crank no start.
    · 14 500
    Yeah I just got done using the boroscope and will send the pictures shortly but I did find out that when I rotate the engine it will get stuck at a certain point and when I rotate it the opposite direction a bit and go back it won’t be stuck...
