Worse that could happen with bad tie rods.
nightspeed87
1,761
12
May 2, 2006
Tampa, Florida
Was told i had bad tie rods today when i was getting new passenger side cv axle and boot put on today. Told my tie rods arent very good. This is something i wouldnt have payed attention to but whats the worse that could happen with those :dsm: being bad.
yea thanks for the advice... The guy didnt make them seem horribly bad but the driver side one wasnt in the best shape and he recommended replacing them. But still i know i should replace them asap...
If they are the outer ends, they are about a skill level 2 to replace (removing a wheel being level 1). If you shop around, you can find them for as low as $10 each. The expensive part is the alignment that you will need afterward. Do both inners and outers (2 each) at the same time if you can.
Well my cars been down for a little bit now because of my engine rebuild/and swap and ill just try to make sure i get new ones of those put in while its down. Are they something that normally go out?
Yes, they wear out. I just replaced all of mine, at about 120,000 when wear became noticible in at least one of them. All had some loseness, though it was only slight in one of them.
There are two outer and two inner obviously one each perside.
The outers are fairly cheap, maybe 10.00 each, and the inners are a bit more, around 30-35.00 a piece. You waill also have to factor in the cost of an alignment once you replace them so an additional 60.00 or so.
  • For sale 4G63 Race parts.
    Brand new seal in box Kigglys HLA 175$ Brand New GReddy timing belt no box 175$ Like New Magnus...
    • GST2012GSX
  • For sale 2g 2G Black Steering Column Plastics
    2G Black Steering Column Plastics $35 + shipping & paypal feesYou must be registered to see...
  • For sale 2g 2G AC Delco Starter ( Tested & In Great Condition )
    2G AC Delco Starter ( tested ) $45 + shipping and paypal fees* fits 2G GSX & GST with manual...
  • For sale 2g 2G Black Center Vent & Switch Plate
    2G Black Center Vent & Switch Plate $40 + shipping & paypal feesYou must be registered to see...
  • For sale 2g 2G Hatch Seal
    2G Hatch Seal $35 + shipping and paypal fees* some small imperfections but still solid with no...
