Wipers?
EagleClawz
Mar 9, 2010
Regina, SK, Canada
So i was working on some wiring and stuff on my wide band guage, and the water pressure guage. Somehow during the process my wipers dont work anymore? Not a fuse problem. No idea what happened. Please help.
The first question is where did you tap power from? There is a power wire for the wiper relay along with intermittent, low, and high-speed outputs.
If you suspect the motor itself, you can always hotwire it as a test for functionality.
Dude, I had the same problem! I was trying to take the wiper motor off the car to clean it, ended up giving up, put the 4 bolts back in, and ever since then I couldnt get my wipers to work.
Verified power, everything should have worked.
Forgot to tighten the 4th bolt in the lower right which also had the ground for the motor
Ground not grounding, motor didnt move.
Tightened it down, punched myself in the face for being so stupid, enjoyed working wipers.
