winter storage....
packinkimber45
378
3
May 26, 2006
Boise, Idaho
Hello everyone. My motor is currently out of the car since I am doing maintenance on the car. My motor is on the stand upside down with the oil pan, crank, and main caps out of the motor. Unfortunately I am unable to finish the car since I am yet to find a good condition used crank. My question is.... it's starting to get cold outside and everything is in my garage. I dont think I will get it done within the next month or two. What should I do to make sure the motor doesnt rust internally due to moisture from getting cold. How about when I get the motor put back together but not running, any precautions I should take? Everything that is exposed that might not have any oil left on the surface I was thinking about spraying with wd40, is this a bad idea? Would there be any reason for me to have to take the motor apart completely to take off the wd40 off the parts and motor once I get all the parts I need to put it back together? Thanks.
I would wipe down the inside of the block with motor oil (just a coating) then bag the engine on the stand and duct tape it up. Any other small bare metal parts I'd do the same with.
X2 motor oil or a really heavy coat of WD-40 will work. Just make sure the bag is sealed off and duct tape the hell out of it you'll be good.
I was told a heavy spraying of WD-40 on everything would be fine. Do it once a week and make sure you cover it up with plastic and seal it the best you can to help keep the moisture from getting in.
Plastic bag everything you can and get as much air out as possible. Maybe throw in some of those Do Not Eat silica packs that come in everything electronic now.
  • Wanted 6 bolt NT water pipe
    • chrisman287
