Will this fit a 1g?
depending on your radiator/fan setup it may or may not fit. with pieces this custom its hard to tell 100%
Technically it will bolt on, but like said above there may be interferance with fans or the radiator. Also .depending on what turbo you put it on you may need to remove the internal flapper if it has one.
well, i plan on putting a fluidyne in it anyway and you can get away with one fan on the passenger side. i knew about the internal flapper having to come off. any tips on taking it out? thanks for the info guys.
