Will these tires fit ? (225/55/18)
VPrime
802
3
Feb 5, 2006
Lonon, ON, Canada
Hey I have a set of 18x8.5 wheels with a 40 offset. My car will be lowered on tokico blues with Eibach sportline springs (so 1.7-2" drop).
I found a good deal on some 225/55/18 wheels and I am wondering if they will fit on my 2G GSX?
Thanks.
lets just say my car did not make it off a flat-bed when i had that suspension setup
this was on 235/45/17 on the stock gsx wheels
and thats of course if you care
I don't mind the spedometer being off, or the issue with tow trucks...
I just don't want them to rub every where. I can deal with rolling the rear fenders if that is a must..
Has any one ever run this tire size combo?
The problem isn't that your speedometer would be off, the problem comes from your setup being about 2.25" larger in diameter than stock. I don't know about your setup, but on my car, I know I couldn't get tires that much larger in diameter to fit. It would start rubbing control arms.
Ah yes, ok thanks.
So what would be a good size to look for then? I have been reading 235/40/18? Is that what I should be running?
you were running 235 wide rubber on 6.5" wide rim ??
maximum on GSX rims are 225 .....
