will i notice much of a difference?
1sick91tsi
149
Feb 13, 2004
pipersville, Pennsylvania
ok i have a 1991 tsi talon awd, this is what i have done so far 16g turbo, 2g throttle body elbow, 2.5' downpipe, custom o2 housing w/dump, 2.5 custom exhaust, high flow cat and muffler, dejontool intake pipe, magnecor plug wires, k&n air filter, custom upper intercoller pipe 3', halman boost controler,ported exhaust manifold and turbo exhaust housing, boost gauge. i just got a datalogger with softwear from pocketlogger.com a s-afc and a 190lp fuel pump. i was running 12 psi and i was going to go up to 15 psi with this upgrade and i was just wondering if anyone might know if i will notice much of a differece after i have gotten the s-afc all dialed in and tuned right. Also what do you guys think i should do next and ideas and input would be greatly appreciated. karl :thumb:
he didnt ask what your setup was....
in regards to the question...i honestly dont believe you will feel too much...i didnt feel alot from 10 to 18 on my t25...but i coudl be wrong so
Just turn it up one dial at a time and test run it. With your 190lp, you should be able to run 21psi, mine does. I didn't start using SAFC until I upgraded to 2g mas and 550cc's.
