will i legit make a difference in my car with these few mods
davetheman81
163
Jun 16, 2010
randolph, Massachusetts
i have a 92 talon tsi stock with 14b, runs great, im picking up dsm link v3, a 2.5 inch turbo back exhuast, 2g maf with pipe and pig tail, wideband, bpr7es plugs and ngk wires> will i be able to make a substantial amount of power with the 14b , stock injectors and stock fuel pump vs the stock map and setup thanks
link will help you free up some power but dont expect much, get a fmic, and some fuel mods and turn up the boost if you want more power, but link is definatly the best place to start modding your car
You need more fuel before you can make very much power. The 14b is going to start maxing out the injectors at 15psi. That is about all you can run safely, sure people have run up to 20 but I'm sure as hell it wasn't as "safe" as they claim. But you can't argue with these morons.
Dont forget the upgraded fuel pump! If you're not looking for big power then Id go with a 190lph...you dont need an afpr for the 190. But go with a 255lp if youd ever wanna go bigger.
  • Wanted 6 bolt NT water pipe
    • chrisman287
