will eclipse halos fit on talon?
Misterio
134
Mar 16, 2004
pittsburg, Texas
I have a 95 eagle talon with blitz body kit and i want to buy the 95-95 halo projectors headlights on ebay. before i buy i want to know if the talon headlight connections are exactly like the eclipses. will they work?
do i have to take off my front bumper to take off the headlights... i hope not..
also i need some 97-99 reverse lights
It depends, there are 2ga lights and 2gb lights, you obviously need the 2ga lights which are 1995-1996 the 2gb is 1997-1999 which will require to you get a new front end that is compatible with the 1997-1999 lights.
And yes you need to remove the front bumper, there is a bolt under the headlight which is a bi*** to get off!! Unless you want to break it off then you don't have to remove the front bumper. :p
All 2g Talon's have the same headlights as the 95-96 Eclipses, so yes, if the halos are supposed to fit 95-96, NOT 97-99 Eclipses, then they will fit. It's a huge pain the the ass to get the headlights off without taking the bumper off, but you can do it, though it's pretty easy to take off the front bumper anyway. There are four bolts holding on each headlight, when only the top two are really needed, so it'd be a good idea to just take the front bumper off anyway, then when you put in the new halos, only put the top two on, then it'll be easier to take them off in the future.
wrong, if you have a 2ga you can use 2gb lights, but not vice versa, where did you buy your blitz bumper? did you buy it for 95-96 or 97-99, or better, do you have the stock lights on your car right now?
i bought the 95-96 front bumper off of ebay and yes i have stock "fogged up" talon headlights
i understand the whole headlight fitment thing what my question was is will the halo projectors that are meant for eclipses plug right into my talon headlight connections.
i know that all eagle talons have the longer headlights (eclipse 95-96)
and that eclipse 97-99 headlights are longer
97-99 headlights will fit in a 95-96 front bumper but there will be a gap between the center of the bumper and headlights
95-96 headlights will fit in a 97-99 front bumper but the bumper will slightly overlap the headlights at the center.
i know this --^ i just have the questions about them plugging in properly because my talon to eclipse tailight conversion required different (eclipse) plugs
