which one?
h3o
290
6
Mar 11, 2005
everett, Washington
should i save up for a safc and another datalogger(that works)
or a maft with the dsm chip stage #3
which would be a better setup for the money?
im moving up to 550's in a lil bit so im going to have to get something to compensate the injectors
DSM Chips Stage III will compensate beautifully for your injectors. Unless you absolutely need a blow through setup, just the EPROM ECU and chip will be fine. Although most people would correct injector deadtime and global settings with the MAFT, the chip will do this for you to the point that you wouldn't have to correct at all using any other device unless you were running racing fuel (make it a bit leaner up top).
Hope that helps,
Andy
does the maft deal with timing?thats the only reason i was thinking about getting it i was just gonna recirculate the bov again if i did get it. i wanted the dsmlink but it will take a while before i save up for that. do you think im better off with the safc and the chip?
