Which camber kit to get??
slo95tsi
Jul 16, 2006
Warren, Michigan
My suspension is on back order right now so while waiting im just going to go ahead and buy a camber kit also. I ordered the tokico hp suspension kit on extremepsi. Its a 1.75" drop with springs and struts. Im really not sure what camber kit to get for this does anyone have a similar setup and maybe could point me in the right direction? Thanks a lot guys!
I think the majority of people on this forum will suggest that you make your own. Follow the instructions in the Vfaq. Contrary to popular belief, the camber being out of adjustment isn't nearly as important as the toe being out of adjustment. If you follow the Vfaq you'll be fine for the rear... the front really doesn't need a kit, the negative camber that you'll get is very minimal.
If you insist on getting a camber kit, The Ingalls one is the best for the rear. I had purchased a rear kit for my 1Gb when I did the springs and shocks, but opted out and sold it off once I realized that my back camber wasn't that bad. It's still within spec.
I believe mine is the same as the "vfaq" that people have mention. Its just some longer, proper grade bolts & some washers. It worked fine for me, I run the Tokico kit as well (with the Illumina shocks). I picked it up from a local DSM vendor for like $20, just because it was eary. If you sourced you own parts it will save you abit. For the front, my camber was a good amount out of spec (like -2 or -3). I'm not sure what the tech did but he brought the negative camber back to -1.25 as I requested & I didn't give him a front kit.
  • Wanted 6 bolt NT water pipe
    • chrisman287
